Need help developing a native app audio recorder
Hi all,
As part of a client project, we need to hire a freelancer to build a small plugin that will work (similar the in the way BDK native does) and allow for the user to record audio using their iphone, and more importantly using the native iOS recorder system in order to work in a wrapped app submitted to the app stores.
BDK Native works perfect for it, but unfortunately the recorder UI (the library used) isn’t what my client wants as they want to replicate the Facebook messenger/iMessage style UI for recording.
Please let me know if you can help here.
Reece
https://kaliatech.github.io/web-audio-recording-tests/dist/#/test1
Hello @help I’ll be glad to help you out with this.
Check your PM please and feel free to leave your request on my mail (Kevin@therapidhire.com)
Warm Regard
Kevin Parker
Hello @help Reece,
You can contact Camilio (Jasonelle) and he will build it for you in less than 24 hours. I’m already using a beta version. It is not in Jasonelle production until the Android part is done. BDK is using the same Jasonelle old audio none customize interface. The new interface is customized. Works great. :arrow_right: Contact Camilio on Telegram. Let me know.
Thanks - just sent you a pm
Bumping this up as so far not found a fit
Hi @help
Please check your PM ,
I would glad to assist you
Regards
Kevin
@help did you end up getting a solution here? I’m trying to do almost exactly what you were trying to do. Anything you can share? Or a recommendation on who helped you?
