The multidropdown isn’t really doing what i want it to do. It chowing all members inside of a space in the same column, I want all the members to be shown separate columns
Here is a screenshot of all the choices sources, option captions and constrains that i put in.
It looks like you want your options to be Team-Members, but your Choices Source is Team-Spaces. How is your data structured, and can you elaborate on what you’re needing the drop-down to show?
(btw I would call a post like this ‘Multidropdown source choice issues’ or something like that)
I struggled a lot with this one, I am pretty new to bubble and starting to learn all the terms, i am shore you’ve been in the same position. About choices source, “Team members” isn’t a data type in my data base so it wasn’t an option, i know it looks pretty messy but that was the only thing i could come up with. Regarding what I want the dropdown to show, I want it to display the list of members inside of the “team space”
Figured it out, it looks messy but it works
100%! You can look through my history here and see some very similar posts even recently - we’re all in the same boat, no worries
Glad you figured it out though! I noticed you said it ‘looks messy’ but that’s actually quite common the more complex you get with the logic. Great work!
