Need help fixing Bubble + OpenAI workflow (AI generation not working properly)
Hey everyone,
I’m working on a Bubble app where users answer 4 questions and the answers should be saved and sent to OpenAI to generate personalized business recommendations.
The UI and results page are already built, but the workflow that saves the answers and generates the AI output isn’t working correctly.
The results page should display:
• user traits based on answers
• explanation of why certain businesses fit them
• 5 business ideas with title, description, and estimated startup cost
I had it partially working before (AI response was showing and I was able to extract data into the page), so I believe it’s a workflow/API connection issue.
Looking for someone experienced with Bubble + OpenAI who can help troubleshoot and fix this.
Open to paying for a quick fix.
Happy to assist. :blush:
I can do a coaching session with you to help you fix it. Probably just be an hour if you have most of it setup already.
Happy to help :smiling_face: and check your DM
