Hello Bubble Community,
I am developing a plugin for one of my client. Plugin development is almost done, I just need help in one area. I need to create a group of fields as in below image. You can see “Value Setup” and “Arc Design”. I need same headings
There’s an Info section as shown here which you should be able to use for that, hopefully it will help.
You are awesome. Thank You
