hi so im trying to get my app to a domain can i get some help thanks! ( i need help putting the stuff on my hosting)
You cannot put Bubble app on your hosting.
But you can set your domain in Setting tab / domain
@retrosolutions If you’re referring to how to setup just the domain name:
In your Bubble App, go to Settings > Domain/Email > Enter your domain name > Select ‘Set up this domain’.
Grab your new IP address and head over to your domain hosting provider > Add an ‘A’ record. You’ll also be provided a ‘www’ when setting up in Bubble, you’ll add this as an ‘A’ record as well.
Go back to your Bubble App, go to Settings > Domain/Email > Select ‘Check my settings’. If all is well, check the box underneath for SSL encryption.
You should be all set afterwards.
