Need help with an RG and constraint
I have this RG with a constraint to select only when Module Complete >1, with the Parent Group defining the Users.
Now I want a similar constraint, this time in a group with an option set but I cannot get the syntax correct.
Here’s my parent group:
I’m trying to make a constraint to search only for items in the the opiton ALL NAV MENU with Module = 2, but I can’t finish the syntax!
:slight_smile:
Should be ‘this options attribute’ with attribute being the name of attribute on the option set that is the number value you assigned it
OK, I got that piece done:
Now, what I am trying to do here is get a count of the option set: "All nav menu: count based on attribute <2. I can’t figure out the syntax.
Count operator after filtered operator in main expression not the filter constraint.
oooh, it worked!
Great job, Boston. Thank you for helping me. That solved my next question as well. :slight_smile:
