Need help with custom plugin
Hi everyone,
I’ve created a plugin, authorized the plugin for one of my apps (using the name as displayed in the homescreen) and finally published the plugin (private).
However I have no idea how to now add the plugin to my applications, it seems it should be something easy but can’t manage to figure it out.
Hopefully someone can point me in the right direction!
Once you have 1) set license to Private 2) published the plugin and 3) authorised your app you should be able to search for it in the normal plugin browser.
If still not showing then maybe try removing auth, publishing a new version, and then re-adding auth. Once you refresh your app it should be available for use.
