Need help with design on bubble, I am having issues
I have been trying FOR DAYS to get this to be organized. It was fine THEN IT WASNT.
Also, how do I keep text centered to the screen to go across all types of screen. HALP!
Make sure you don’t have any overlapping groups (ex. hidden group on top of another group) as this can mess with responsiveness.
Another thing you can try is to group all of the buttons in the same row together. Raise the group that holds the row of buttons so that it’s touching the group above it. This will ensure that it won’t move higher than it needs to be on the preview. (if that makes an sense)
Also I like those button icons. Did you design them or do you mind sharing where you found those?
Thank you! So templates have hidden groups, how do they make it work?also, I used creative market for the icons !
If you want you can share your editor link and I’ll see what I can do.
