When I check my DB, the image size seems to be 4-6MB which is an overkill, is there any way I can reduce this to like 500-600kb?
Second challenge is, I need to trigger another step after the image is captured, how can I do that? because once the image is captured I will send the user to another page.
I tried to check the forums to see if I can do a workaround, or if there’s any plugin that I can install but I couldn’t find anything yet.
This is the only thing that’s stopping me from going ahead. Is there anywhere with timelines / roadmap on what they’re working on fixing and/or adding for mobile app ?
Other than this comment from a couple months ago, no.
I hope it’s a priority. Anyone building with AI is missing a critical feature - go ahead and try uploading like 5 images at one time on cell service (not wifi) and it takes unacceptably long. It’s not even usable.
