No the inputs,
That’s the step!
When you click on the workflow name, the properties window for that.
Why is the parameter called date a “post date” not a “date” ?
Social Platform, Social Account, Post Date are tables within my database that are list fields on Social Post
Ok so the second workflow single account single platform list dates, let’s look at the input parameters to that, and the step where it calls the final workflow
This is the end point Single Account - Single Platform - List Dates
Here is the API Call on List that calls the Single Account - Single Platform - Single List
You need to change those inputs to account and platform, not account ‘s name or platform’s name
Ok, now it is posting the social platform but it still not posting the social account. For ease of looking at the whole thing, I created a graphic with the entire workflow.
@jasonh which api are you using?
Ok can you look at the element multi drop down social platform, and what kind of value it is set up to be? It should be a list of social platforms
Not sure what you mean, but I am running and API on a list 3x.
Sorry. I didn’t ask correctly.
I meant to ask which service are you using to post on different social media accounts for different individuals/businesses.
Ok,so the last place to look is at the workflow on the button , can I see that?
And the privacy settings for social account, those too!
I am sure we’re nearly there.
It’s account that’s not going in right! Can I see the states/inspector for those?
ayrshare
The button doesn’t do anything. The workflow is triggered by the change in the status, which is pictured in the workflow above.
There are no privacy settings for social account. All social account does is provide the 2 (for now) accounts and their associated name and api key for later use.
If you don’t have any privacy rules at all then this could be the problem.
Set one up that everyone can do everything and run your workflow again, if it works then we know that’s the issue, and you can tune them down a bit.
