Hello, i am trying to create an AI quiz generator with a template I purchased on bubble.io. The API that came with the temp did not work for me (I copied it to my other app) so I have been tweaking it to work for my app. The issue I am having is with the generating response. It adds the brackets and it also adds the answer with the last option.
I generally tend to use the ‘extract with regex’ function to grab what I want from the object after the fact, since chatgpt still only returns a JSON object string, as opposed to an object. Something like…
(?<=\"Question":")(.*?)(?=\")
The above repeated for each required field should get you the content of each key/value without including the enclosing brackets or quotes.
Send the response to a backend workflow and inside of it use Return data action, set content type to json and it will give you the clean object with field values to pick from.
