Need help with repeating group workflow
When I click on the group inside the repeating group, there is no action even though I have the work flow. can someone help point me in the direction to see what am doing wrong here
Looks like you want to navigate to the same page again with different parameters, correct? I’ve also encountered issues in such scenario. Bubble does not always refresh the page.
Since it looks like you are building a mobile app, don’t use the the URL params to control the app behaviour, better create a custom states on page level and keep changing these states.
Thank you, will try that out
Tried it out still no joy on set states yes or no
All solved, I used custom states and used hide element when not in use to switch states
