I am trying to set up below curl call on API connector.
I am not able to set up the highlighted part i.e., nested data.
I have tried import curl call as well, It does not import the nested data.
Can anyone help me with this?
Thanks,
Ram.
Paste into the api call directly, not relying on the import curl…since you already did import curl, just add in everything that was omitted through the import curl function
