Need to do an org chart in nocode no problem with the plugin
GS Org Chart Pro
GS Org Chart Pro, a powerful and intuitive plugin for Bubble.io designed to help you create, manage, and display organizational charts with ease. Whether you’re building an HR application, a project management tool, or need to visualize team structures, GS Org Chart Pro is the perfect solution for bringing clarity to your organizational hierarchies.
With GS Org Chart Pro, you can effortlessly construct detailed org charts that showcase your team’s structure, from executives to team members. The plugin’s user-friendly interface allows you to add roles, departments, and connections, giving you full control over how your organization is represented. It’s fully customizable, so you can tailor the appearance and details of each node to fit your specific needs.
Program setup
