That’s gonna be useful thank you
Please let 2FA be managed by Starter plan apps. This is a awesome feature to distinct new apps in the market. This is perfect for app customers these days considering cybersecurity threats. Every paid account should have it. :]
I connected my App to use Two Factor Authentication from Bubble.
The QR code and everything works fine with Google Authenticator but when I sign out and then try to Log in again.
The Login workflow fails with " [Sorry, your login session has changed / expired]"
Is there a solution for this or Has anyone successfully implemented 2FA on user sign in? @emmanuel
Does anyone have an example of this working properly?
Hi, thank you very much for your explanation, it helped me a lot. But I have a question: when I redirect the user to the page where they need to enter the token, they are not logged in yet, right? And when I perform the check, do they log in automatically, or do I need to log them in first and then redirect them to the app?
From Bubble pricing perspective, 2FA codes have a cost of $0.05 or so, per request. If you have a Starter plan app with lots of users accessing, it eats the costs away. So, does make sense for Bubble to only offer on the $130 and above.
You can also build this yourself with 2 API calls from Twilio: Start Verification & Check Verification. (My 2ç)
Hello! Have you found a solution for this?
I found setting the 2FA pretty easy (the documentation is really unsatisfactory for cases like this, though), however I cannot make sure the user can login in case they do not have access to their authenticator app. In this case, they are basically out of the platform.
I guess there is no workaround to make sure the user can login or contact the admins to disable the 2FA.
Cheers!
