Opportunity for pos thermal printing bluetooth
can anyone understand what this means? im trying to make a connection on bubble to this application to allow one click printing from bubble apps and websites.
Following this. I have this same problem
hi adunniola, i found a way around it for the time being. do you need it to print to a thermal printer by webapp or by native phone app? the way i found for now only works with the webapp so you can print on your phone and computer. let me know if you want to know and ill tell you on here :slight_smile:
Please i need it. Both on web and mobile. On mobile its wrapped with go native
i couldn’t make it work on the mobile native because i didn’t pay and its on test mode but it might work, ask the native wrap provider encase you can use the inbuilt printer function for the phones.
i added the print screen plugin from bubble, and i downloaded a print service provider on playstore, i went to the phone settings and changed the main printer to the app i downloaded. when i click the print screen button (the plugin) it is set to print on my thermal printer 58mm automatically. only bad side is it shows you the preview screen before printing its not that bad, you can also use any thermal bluetooth printer, even the ÂŁ25 ones :slight_smile:
