Looking for some assistance. On a record I have a list of values from an option set: Category 1, Category 2, Category 3
How do I do a search to find records that contain Category 1 OR Category 3?
You can:
Advanced:
filtering (keep in mind that this operator is applied client-side, so you’ll use more WUs for fetching data from the DB) if you are comparing two lists like List A = Thing’s list of options) with List B = some list of chosen categories (for example, from multidropdown or some list custom state).Do a search for Thing
where Thing’s list of options contains “Category 1” :merged
with Do a search for Thing
where Thing’s list of options contains “Category 2”How do I get advanced to appear?
I found that if I do the merge, then I can’t sort the entire list in a RG by a field, it seems to only put one sorted list after the other sorted list rather that sorting the two lists as one?
Apply :filter
operator to your search. And there you’ll have the Advanced:
option.
Have you tried to activate new expression composer to get parenthes functionality and apply :sorted
operator to the result of the merge?
Thank you!
No - I will try this.
I’m almost thinking it would just be easier to use a list of text instead of option sets as they seem quite limiting. Is there a benefit to option sets over text?
@psten00
One of recent @georgecollier forum replies reminded me about the third option - compiling a list of constraint values.
So in your Do a search
expression you’ll have something like this:
Category is in Category 1:converted to list:plus item Category 3
This approach is more scalable and comfy cause if you’ll need to extend the list with additional category - you’ll just need to apply :plus item Category X
to the expression above. While dealing with merging searches (option 2 from my post above) you’ll need to :merge with
a new Do a search
expression.
BTW, somehow I’ve decided that you are going to hardcode constraint values right into the data source expression. IDK why that came to my mind, may be I was too tired
So are you looking for an option to hardcode values right into the search or your real question was about making dynamic searches (user chooses multiple categories - list of Things is filtered by chosen categories)?
