Hello,
I would like a bit of guidance on how to go about allowing users to access their Pinterest collaboration board on a page. Any advice on this will be much appreciated. Thanks in advance.
Hello,
There’s a pinterest plugin that you should add to your app that will allow this. I’m not sure how much it allows though as I haven’t used it myself so check it out and see
Thanks. I’ve been fiddling around with that, but it’s not really clear. I continue to poke around.
Definitely post here what’s not clear - take a screen shot with the part that’s not working right for you.
It’s super easy to get other Pinners to invite others to your group board. Remember, you have to own your group board. Have a look at the image
Click Edit, and you will see this image pop up. Go to the bottom of the page and where it reads “Let collaborators add people” turn than slider to red, and then “Save”.
Thanks guys for all your help!
Essentially what I am trying to do is create an idea board where employers and workers can share ideas. So for each project there will be an idea/mood board.
So far I have:
I need to figure out:
Many thanks
