Please help me setup push notifications using onesignal
I want to send notifications through browser in both mobile phones users using the site using chrome or safari and also the web users using through pc or laptop how to do that i am trying using the onesignal api from like around a lot of time but feeling stuck with no solution and please help me with setting up with its api if you are good at setting apis and if have any solutions please tell.
Thanks for giving me such a important part of your time
thank you
Harman sharma
Hi @yashsharma140404
Help us help you.
Please elaborate on where exactly you are stuck. What setup have you already done with screenshots or loom.
Are you not sure where to start or you are stuck on specific error or you have done everything by the book and it still doesn’t work as expected.
Overshare! except API keys :sweat_smile:
Hello Yogini
I am trying to setup the onesignal api key and as i am new to it i am unable to properly setup that. Like before i have also tried and was able to create a new user but when i tried to create subscriptions i was facing multiple errors. If you go and check out the onesignal api you will get it. I have awesome idea for you can start your youtube channel and post videos around building features like push notifications and bunch other it would be a great help.
I want a video solution setting up onesignal through their api and in that try to create a subscription also in which the chrome push should be enabled
Thanks for your time
Hey @yashsharma140404, have a look on this post. You might get more help.
