Possible? Mouse over, display more info, overlay on top the next row
When a user mouses over a thumbnail of an item, I want to expand the item to show more information. The expanded area is displayed on top of the row below, without increasing the height of the 1st row? Is it possible? If so, how can I do this in Bubble?
Here is how it should work.
It can be achived in RG with use of reusable element and groupfocus. It was discussed on forum many times, search can help you.
Can you tell me the keywords that I can use to search for the discussion? I am pretty bad with design, so it is hard for me to know the keywords needed to do the search. Thanks.
