I m creating a survey for people that have to be answered before they get registered. Before the registration of the user, I cannot save the survey’s info in the DB with the relative creator (obviously the customer), cause naturally is not registered yet.
I stored the standard questions and relative possible answers in a Option Set with Questions and as an attribute, a list text with relative possible answers.
Now, I created a repeating group that get data from this options set and show it to customer.
Here is the problem: i ve tried everything in order to get it automated but I need a simple and not time consuming way to save these answers and then attach them to the customer after the registration.
I ve tried customer Custom States with the repeating group but the fact is that I can’t retrive them after.
Yes you’re right. But you could schedule a conditional workflow to delete the db rows. (maybe, if the user doesn’t register during the next 2 days or something)
Second part means that if you save something to the db, the created by is current user even if this user is not registered. If the user registers then, it will turn into this user.
Ok that makes sense. But have last question: if two people are answering the same survey at the same time while not being registered, does it create some problem in assigning the right registered user to his survey answers? @daviddr17
