Hello, community,
I have a problem with the plugin “AirKeyboardShortcuts” since a few days.
When I press Enter the text should be saved as a comment.
Now to the problem. Sometimes, strangely enough, the workflow only saves the first character from the input. Photo is attached.
Can somebody help me? ![]()
@j.hennersdorf I’m guessing here but is a half-educated guess based on previous experience. I suspect it might be because bubble has a lag on input fields. I think you are saving before bubble is recognising all the characters. The same AirDev people have a plugin called Instant Text and if you set it to watch the ID of your input and save it instead of the input I think that will work. The alternative is to put a pause in your save workflow os it waits for a second or two before saving.
two different developers Air Keyboard shortcuts is created by @seanhoots https://bubble.io/plugin/air-keyboard-shortcut-1518279603919x687476512969195500
Nice catch @Bubbleboy - must be something in the ‘Air’
Hi @j.hennersdorf
One workaround involves creating a second transparent input on the page. In summary, after the User types into that first input that you have, and hits Enter, the steps would be:
- Set focus to the second transparent input
- Save the value from the first input using the Make Changes to a Thing action(s)
- Reset the value of the first input
- Set focus back to the first input
That should make sure the entire value of the first input is saved, but let me know if not!
