Problem with dropdown filters for a repeating group
I am attempting to filter a repeating group using 3 drop down filters. The first of which “Investment Type” is working exactly how it is supposed to but the other two are not. All three filters have been programmed identical. I attached a photo to show each is identical. Thanks!
-Nick
Screen Shot 2022-03-14 at 10.25.16 PM
Screen Shot 2022-03-14 at 10.25.38 PM
Screen Shot 2022-03-14 at 10.25.50 PM
Are you checking the box that says ignore empty constraints?
I don’t see the option. Attached a picture.
All 3 have the same configuration but only the first one works. Maybe I need to create a way for the 3 filters to communicate. First works perfectly but the problem with 2 & 3 are they yield 0 results.
:confused:
-Nick
Share the settings where you use the dropdown to filter RG (Do a search for or :filtered)
Hi Jici,
I think I already have. Check the above messages. If not, maybe I am in the wrong place. Let me know if the images above help or not.
-Nick
What we see are all related to dropdown, not to repeating group
Ok does this help?
-Nick
No. What you are asking is to filter the repeating group. What we need is to see what you have set in the data source for the RG. All the settings related to the data source (probably a Do a search for…)
The first is the working filter & the second photo is one of the ones that are not working.
-Nick
You post screenshot of text element. What we need to see is the repeating group element
Ok, sorry about that. Looks like this.
-Nick
Screen Shot 2022-03-15 at 10.31.27 PM
Can you post when you click on the search for company settings? This is the main thing to check
I see the button “ignore empty constraints” but I selected it, refreshed and tested. But, nothing again. First filter still works, others do not. (BTW: Thanks so much for ur help)
-Nick
Screen Shot 2022-03-15 at 10.46.37 PM
GOT IT!
Thanks for your help. This was the problem.
-Nick
