Hi there,
I successfully installed Sendgrid, I tested it and it works well but I still get an error message once I land on the page with the actual email workflow. Please find here the error message. Does anyone have an idea from where this can come from?
Thanks in advance for your precious support.
A.
Here is a link to my page . The error message appears when I click on the block therapists
Hello @antoine.sepulchre
Looks like plugin error
If you are using Sendgrid plugin from copilot
Then i don’t know why there are lot of bugs i see these days from this plugin
Maybe they are outdated…
Good morning @mdburhan3
Yes I actually use the copilot plugin. Maybe I should try the API connector and pull up the JSON directly from Sendgrid if the copilot plugin is outdated ?
Thanks for your feedback
