Problem with the cursor
Hi guys
Here’s my problem. For some time now I can no longer use the arrow keys to move the cursor within input fields. This is not only annoying, it is also very user unfriendly. What can I do that I can move the cursor again with the arrow keys?
Thanks
I’m using this plugin [Free Plugin] Air Keyboard Shortcut to catch enter and esc keys and it works really well. I am not looking at arrow keys but it does that too (up, down, left, right). I suggest you try this plug-in and see if it does what you need.
Thank you!
I have tested the plugin now, but I don’t know how to use it to move the cursor within the text field? How can I move the cursor?
