when i try to preview the “animate” element in workflow it does’t work, it is like blinking, impossiblem to chose the right animation. How can i do? Is it a bug?
@claudio.soldaini
Actually there are various ways to show an animation. Animation is depends on how you use as in element and what the workflow you used with conditions. Also there is an option that user can give a durability or durable time for your animation.
Hi, I have the exact same problem. Have you discovered a solution? Maybe there is a public project out there where you can at least see each animation in action.
I am also having this problem recently. In fact, I might just add that the Bubble Editor in general over the past couple of weeks has been really buggy for me. I don’t know what’s going on there but it seems like they’re making changes.
