I have 3 different checkboxes, and the user is supposed to select only once. In order to do so, I had set conditionals on each element. Indicating that when any of the other 2 checkboxes are checked, the preset status of the current checkbox will be: Unchecked.
However, this conditional is not applying when I run the app on the preview mode. Why is it? And how can I work it out?
I completely agree with @jakubdab on this. Checkboxes tell the user that they can select multiple items whereas radio buttons tell them that they can only select one of the options.
I’d strongly recommend you use radio buttons for this because: 1) that’s more intuitive to the user and 2) radio buttons are designed for this from a technology standpoint so you won’t need any custom logic.
