I have been acquiring paid users on my app for the past 12 months.
We are reaching the point of some larger deals in pipeline, the result will be a material number of users onboarding on to the platform.
I need to begin working on load testing and some QA on my app to gauge stability and number of concurrent users running the same processes at the same time etc.
Has anyone carried out this type of work on their app or can they recommend anyone for this type of work?
I would recommend flood.io with their Element testing option. There is a Chrome plugin for Element that lets you record test scripts in your browser which you can then upload to flood.io for actual testing. Without a good deal of scripting knowledge, load testing seemed kind of hard to pick up and this was the easiest option I could find without crazy prices.
You can use ddosify. It has a very easy to use UI and supports 25 countries for geo-targeting. It is also very affordable and has a generous free plan.
