Hi there,
I’m using “QR Code to SVG Generator” plugin, an coverting a THING ID to SVG, resulting in smthg like…
Can I Use IMAGE component to display resulting QR Code?
How to achieve that?
Tks in advance
Hi there,
Tks in advance
What do you want to achieve?
Store a thing ID in a QR and display it as an image?
Yes! Just it !
I use this plugin to generate QR codes
You can generate QR codes with this action
Store QR codes image in the DB like this
And display the QR code like this
Tks Very Much !!!
