Hello,
As you can see on attached screen i got some styling for text element when User sends messages to each others. Is there any way to style text element that when only emoji is send styling will be different?
I don’t know what the actual emoji is sent as but you should probably be able to use an extract with regex pattern to check if an emoji is sent and have that be the conditional trigger
