Repeating group is not loading
Hi everyone!
I am trying to create a repeating group but when I press preview it does not load, contrary to other pages whoose repeting group works fine.
The “the element is visible on page load” option is checked.
No workflow actions are created for this element.
I have attached some images from the app and the debuger
Hey @kalod123
From the debugger the Data Source appears to be empty. Can you send through a screenshot of the repeating group element within the Bubble editor.
Just to check have to you set a type of content and data source on the repeating group element?
ok, it seems that the data source had not any data, so now I tryed something else and it worked.
Good stuff, glad you’ve got it working :+1:
