Repeting Group For Input
Good afternoon,
i have tried looking in the forums but have not found the answer, this seam to be somwhat easy, i have a repeating grup the shows a result of 5 rows, i would like to know if there is a ways to take that result in the RP and use it as inputs and save data bak in to database, the first image has at the top an example of what i had to do in order to get the imputs in the data base and if a do it that way y locked in to the 5 rows that are in my data base, at the botom is the repetin group with the input fields that i would like to use as my inputs in the workflow
in the third image you can se the preview page so you can see what i mean.
Thank you in advance
