Hi everybody,
I’m new on Bubble and I have been struggling to find how to set up responsive groups.
I want to go from three horizontal blocks to three vertical blocks, without the intermediate step.
Step 1
Step 3
Step 2 I want to skip
Has someone found a way to do it without creating multiple groups of blocks ?
Should I look at CSS Flexbox solutions ?
Thank you !
Hi @Bohemond
I know that Flexbox can do it but haven’t had luck integrating this into Bubble’s responsive engine . Here’s an example of the “flex-direction” column/row CSS: https://www.w3schools.com/code/tryit.asp?filename=GLL9WXIS4DVQ
Take a look at this post where Flexbox does something else (but related).
Do you know anything about Flexbox and its “flex-direction: column;” attribute?
Okay @Bohemond , here’s an example that doesn’t fully work, but is getting closer. Unfortunately, I don’t know why it doesn’t work, or even how I got this much to work. Anyone with some top-level CSS skills want to chime in?
Also adding in @eli from whom I got the structure/approach in his excellent post.
A few things to point out:
- Designer has boxes in Red, Green, Blue order (left to right).
- Preview @ ≥534px has same Red, Green, Blue order.
- Preview @ <534px has new Red, Blue, Green order.
- This order remains as you reduce page width until 303px.
- Preview @ 302px drops Blue to new 2nd row but is centred.
- Preview @ ≤301px shows correct vertical alignment as all items are in 1 column.
Designer and Preview are available.
