Hi everyone,
I’ve started using Bubble recently, so I’m a “Responsive engine native”. Quite used with creating groups and groups and groups… (although a little less now thanks to padding now).
The last update allowing us to move elements in the Elements tree is a great improvement.
But it still is a bit frustrating to not be allowed to add a new element just where I want.
I wondered if maybe there could be a new option is menu that shows when your right-click on an element in the Editor or in the Elements tree : “Add an element here”, which would add an element in the selected group (if it’s a group) or after the selected element (if it’s something else). You’d select the element in a pop-up, or maybe directly use this function after having selected the element in the left side menu).
I made a quick visual explanation:
I shared this idea on Twitter, and a few other Bubblers liked it (I’m just starting discussing about Bubble on Twitter
). One suggested that the “Add element here” function could also be triggered with keyboard shortcut. They suggested “CMD+K”, as in Figma apparently.
What do you think? Would it be helpful?
Or do you know a trick I don’t know to get to the same result?
Thanks !
