Seeking Bubble Developer for SaaS MVP (Multiplicative Scoring System)
Hi all,
I’m looking for an experienced Bubble.io developer to build an MVP for a tool called BTS – Biglin Targeting System, a decision-support tool used in underground mining to rank drilling targets.
You do not need mining experience — just strong Bubble skills, good logic, and clean workflow design.
This is a lean MVP to keep cost/time low.
1. User Authentication
Email/password login
Admin + Standard user roles
2. Drill Target Form (CRUD)
Users should be able to create, edit, and delete drill programs.
Fields include:
Mine Name
Target Name
Lode / Area
Total Metres
Cost per Metre
Drilling Rate
Estimated Ounces
5 scoring inputs (each 1–5)
3. Multiplicative Scoring Engine
Each target is ranked using the formula:
Final Score = Geo × Strategic × Access × Efficiency × Risk
Admin should be able to:
Rename the 5 criteria
Toggle each criterion on/off
Adjust score ranges (e.g., 0–5, 1–5, 0–10)
No additive model.
No weightings system.
4. Results Page
A dashboard that shows:
All targets/programs
Their final multiplicative score
Priority label (P1, P2, P3 etc)
Cost-per-ounce calculation
Basic drilling time estimate (Metres / Rate)
Drill program schedule
Users should be able to:
Sort by score
Search/filter
View target details
5. Export Features
Export results to CSV or Excel
(Does NOT need PDF; optional later.)
6. Basic UI/UX
I do not have UI designs — I’m happy with simple, clean, functional layouts.
Bubble’s default components are fine for MVP.
What I Provide
Full scoring matrix
Excel version of BTS
Logic for multiplicative scoring
Clear rules for cost-per-oz and schedule
Ideal Developer
Strong Bubble experience
Comfortable with database structure + workflows
Can deliver a working MVP quickly
Good communication
Mining knowledge is not required.
Budget
$2,000–$6,000 AUD for this simplified MVP.
To Apply
Please send:
Examples of Bubble apps you’ve built
Your rate (fixed)
Estimated timeline
Short note on why you’d be a good fit
Thanks,
Jordan
@jordan.biglin Kindly check DM. Thanks
Hey Mohammed, cheers for the info.
I’m just looking through a few replies at the moment. I’ll get back to you soon once I’ve narrowed things down.
Hey @jordan.biglin , sent you a dm, let’s talk!
Hi @jordan.biglin i have sent you a message
Thanks for the update. I will wait for the response.
Hey @jordan.biglin I’ve sent you a DM — let me know if it looks like a good fit.
Sent you a DM @jordan.biglin
Feel free to get in touch. We have worked on previous projects in your sector.
Hi Jordan! Welcome to the community. Thank you sharing this oppurtunity. I have sent you Message.
I’m a professional Bubble developer with custom coding, am interested in your project, i was unable to message you but you can please send DM so i can send my proposal.
thank you.
Hi @jordan.biglin ,
I sent you a DM. Kindly check. Thanks.
Best,
Jayson Tobes
BDR, RapidDev
Hi, I hope you are doing well.
I am Athar, a Bubble Developer who builds clean, scalable systems that help businesses operate smoothly. My recent work includes three end to end products, a service delivery platform named Servinify, a Coaching Planner for football coaches with training sessions, calendars and team management, and a Supply Portal that organizes product requests, approvals and dispatch workflows.
