Please explain what am I doing wrong in Server Script (Java script in Bubble workflow)? I wanna create a new variable in “keys and values”. How to address it in “Node script”?
Addressing it as “properties.keyvalues.temp” or “properties.temp” is not functioning.
First problem: The ‘Node script’ returns a variable of numeric datatype as string.
Example: “let a = 123” is inferred as string.
Try doing this on the last line: parseFloat(myres) and set your return type to string. This worked for me (I was not using properties.keyvalues.temp at this stage).
Second problem: The argument properties.keyvalues.temp returns as undefined. Not sure why.
Tip: You can create a plugins where you can easily write Javascript and loop “things”. I find this to be more robust.
My preferred method for using js with bubble
hey @dimitri.korenev to access the keyvalues data you need to do it like this: properties.keyvalues[0].value
