(solved) Is there a way to display two types of things in repeating group?
It is easy to make a repeating group of user produced content if there is only one type of content that the users can produce, but what if there are two types of content? For example if the user can post text or video.
Is it possible to make a repeating group which displays two types of posts?
Well, not how you’re thinking, but there is a solution. You actually kinda pointed it out yourself.
You’d have one “thing” called a post. The post would have a field called “type,” which could be text or video. Your repeating group would be looking for Posts, and it wouldn’t care if the type was text, video, mullet, hamster, or image. Does this make sense?
Yes, got it. Little messy but works. Thanks :slight_smile:
