Stretch element between two other elements, possible?
Hey forum,
Let’s say I have a fixed element at the top of the page and a floating element at the bottom, with a calendar in between. I want the calendar to dynamically stretch between the two based on the size of the screen. Does anyone know how to do that? That would be amazing :slight_smile:
Thank you,
Benjamin
I use the hero sizing plugin. Works great and you can set it to sit above the footer and below the header. Or anything really. More here:
The example here someone posted is great to see how it works in practice.
Hey @lantzgould,
I wasn’t able to get anything to work. I followed the video and attempted to follow the example. Thank you for trying though.
Benjamin
