Hey Bubblers ![]()
I’ve noticed a lot of people here get stuck at certain points while building their app — sometimes it’s a workflow that won’t behave, a database structure that’s causing issues, a plugin/API integration that keeps failing, or just not knowing the “right” way to build a specific feature.
If that’s where you are right now, feel free to reach out. I’m an experienced Bubble.io developer, and I’d be happy to take a look at your app and help you find a solution.
How I can help:
- Debugging workflows and fixing broken logic
- Database structure and optimization
- API/plugin integrations
- Performance and responsiveness issues
- General guidance if you’re not sure how to approach a feature
Just send me a DM with a quick description of what you’re stuck on, and I’ll get back to you. If you’d like to see my previous work first, I’m happy to share my portfolio as well.
Looking forward to helping you move your project forward
