Thank you very much for your time…well its visible on the UI on some section… i create the tab outside the pop-up and cut-paste in the pop-up… and after that the elements on the TAB ELEMENT disappeared …
We would this problem re-occur… because i do need TAB option for forms… what do you advice @mishav
The groups for Tab 2 and Tab 3 have nothing in them as far as I can see. The elements that are labled as being content for these Tabs are not contained in the Group, so won’t show when their group is shown.
I added some text to both Tab 2 and Tab 3 so you can see what is happenning.
So you need to move your Content to the Group it is related to.
It was maybe because the content group was not inside the tab group, so I moved it a bit (until the border of the tab group went red). And now something shows up. Although not sure if it is the right thing
@NigelG the table had moved off the content tab so it was showing… i increased the size of the group’s but no progress.
Well the Element TAB i picked doesn’t have a workflow … or may be the element state has something to do.
Please make the final golden touch and help me out… am not familiar with element state’s. the Tab button gets clicked … but the content is not appearing
