Tooltip problem and feature request
Hi All,
it looks like the tool tip has 3 points active when the courser goes around
tooltip
can you also please add chart scaling ( allow us to normalize values)
for example if minmum is 100 and max is 150 the chart will draw things from 100 to 150 and the chart space is 100 to 150 rather than 0 to 150
Which chart tool are you using? I believe most of the charting plugins are NOT created by Bubble, so you’d need to post the feature request to the plugin creator. Additionally, if this IS the Bubble-created chart plugin, I recommend filing a bug report in addition to this post on the forum (bubble.is/bug_report)
This is the bubble chart tool
