Trouble with responsiveness: How to build responsive Repeating Groups?
I’m making me familiar with the responsiveness feature. However I cannot achieve what I want.
I’m not getting the hang of floating groups. It could be so easy, but I get an error saying they have to be underneath “undefined”. Instead it is under a RepeatingGroup.
How do I get responsive tables/repeating groups, if I can’t place and floating groups inside them?
I found two Bubble Responsive Tutorials but none of them is solving my problem…
I also tried putting everything inside a reusable element but that doesn’t trick Bubble, it still says the Floating Group needs to be under undefined.
Can anyone provide a hint on how to build proper responsive repeating groups?
Maybe I understood this wrong… I thought I need floating groups, but I guess this means that they are fixed on the page, but that not what I want at all and doesn’t have to do anything with responsive…
Create a reusable element inside the repeating group and place your floating group inside of it .
Thanks a lot. :+1:
I found out two things.
First: The reusable element needs to be a normal Group instead of a Floating Group. Otherwise I cannot place it inside a Repeating Group.
Second: For what I want to do, I do not need Floating Groups at all. :sweat_smile:
Great to see you found your way to the solution.
