Use field display instead of ID for key names dosent work
This feature does not work in the new bubble. Where you can set an element id.
Enable ID
Here you should be able to set the element html id? What is the problem in doing so.
If you mean you don’t find it in your element, then please go to settings>general tab
Here you will need tick the box to enable it.
I’m not too sure what your question (which is about Data fields in the Bubble Data API) has to do with the image in your screenshot (which is about element ID attributes)…
Are you asking about the data API, or about element IDs?
What exactly are you trying to do?
