I run a marketplace, and I am looking for a solution to show customers relevant candidates based on their job postings. Some of the bubble marketplaces are already doing it, and I haven’t found something that addresses this specifically.
How can I achieve it in Bubble? If anyone is already doing it, please shed some light on me.
I’ll just describe it the other way round (users looking for jobs rather than jobs looking for applicants) as that’s what I’ve done before:
Get the description/skills/resume of applicant and get embeddings
Upsert to Pinecone using the unique ID of the applicant
Add a backend trigger such that when the applicant is modified the vector is deleted then reupserted/embedded
Get embeddings the job description + title
Query the Pinecone index using the embeddings of the job (applicants with profiles most similar to the job description)
Return the top few results (the ID of each result will be the unique ID in the database so Do a search for Applicants where unique ID = Pinecone query matches:each item’s id or whatever the exact expression is.
Sorry to response quite late, thanks for detail explanation
may i know what you were using for embeddings OPENAI ?
or is there any other which you can recommend ?
