I see in Bubbles standard GDPR text that codes such as ‘b’ in square brackets works for emboldening text.
Does anyone know the code for a line feed (carriage return)?
I want to send variable text to reusable popup element using a ‘required parameter’. I can use the [b] code fine but I can’t fathom the line feed. I’ve tried \n and \r and br and cr all in square brackets but they display as they are typed.
It would be good if Bubble published a list of codes we can use when we send text to be displayed to the user in a Custom Event (or allow us to use line feeds when entering the text).
Many thanks
Mark
