Complete Guide: Using Firecrawl’s Web Crawling API in Bubble
I’ve used Firecrawl on multiple personal projects so I was thrilled when they reached out about producing a sponsored video. I wanted to share the key implementation steps here since web scraping/crawling can be incredibly useful for Bubble apps.
What This Tutorial Covers:
Using Firecrawl’s /crawl endpoint to scrape multiple pages from a website, extract structured data using AI, and display results in your Bubble app.
Key Implementation Steps:
1. Setting Up the API Connector
- Install the API Connector plugin
- Create a new API called “Firecrawl”
- Add your API key in the header as:
Authorization: Bearer YOUR_API_KEY - Set up two calls: one for initiating the crawl (POST) and one for getting results (GET)
2. Understanding Webhooks (Critical!)
When crawling multiple pages, the process takes time. Rather than waiting synchronously, Firecrawl uses webhooks:
- Create a Backend API Workflow (requires paid Bubble plan)
- Add the webhook URL to your crawl request body
- Use “Detect request data” to train Bubble on the incoming webhook format
- Important: Make your webhook URL dynamic so it works across dev/live versions
3. Database Structure
Create a “Web Page” data type with fields like:
- URL (text)
- Summary (text)
- Custom fields based on your extraction needs (e.g., “Mentions AI” as yes/no)
4. The Workflow Logic
The flow is: User clicks button → Initiate crawl → Firecrawl processes → Webhook notifies Bubble → Fetch results → Save to database
Use “Schedule API workflow on a list” to iterate through results and create database entries for each crawled page.
5. Pro Tips
- Use the
.JSON safemodifier when passing dynamic values in JSON body - Use
Get home URLto make your webhook endpoint work across versions - Remove “initialize” from your webhook URL before going live
- Firecrawl’s playground lets you test and generates the exact code you need
Real-World Use Cases:
- Competitive analysis tools
- Content aggregators
- SEO audit applications
- Market research dashboards
- Monitoring competitor blogs for specific topics
The tutorial video walks through building a working example that crawls HubSpot’s blog and identifies which posts mention AI:
Firecrawl also offers /scrape for single pages, /search for targeted queries, and /map for generating sitemaps - all accessible via the same API setup process.
Happy to answer questions about the implementation!
