Hi Bubblers-
I included quite a bit in the subject line because it’s all related on my app…and if I get one aspect to work, the others stop working.
On my app Know Thy Drink, the live prototype is setup so you search for a cocktail recipe (currently only 5x in the database for proof of concept), that recipe then duplicates into a new recipe, and the user is able to edit that recipe as much as they want. You can try it out at www.knowthydrink.com
What I’m running into is a want a user to be able to just save the URL of the recipe, so they can go back to it, share it, etc, hence the desire for slugs. Know Thy Drink | Bubble Editor
Group Recipe is the main ‘group’ that I load recipes into:
I am trying to make it so when the search box is used, the recipe is found/chosen, and loads into the Group Recipe, as well as the Slug into the URL. I have gotten various successes from this, both with the slug and the unique ID. I then started experimenting with loading Group Recipe from the URL, using Get Path from URL to populate the search box:
Issues: Whenever I try to ‘read’ the slug to load data into a group, it will not work with Slug, only Unique ID. Is there any way around this? Additionally, even when I have gotten the search box’s results to load the unique ID into the URL, and populate the Group with the recipe, when I copy+paste that same URL it will not load the recipe, and instead reverts to the slug of whatever Unique ID I used, which won’t load anything.
Any help with what I’m missing here? Happy to provide additional details-
