Hi!
I’m probably too tire, and I hadn’t been able for hours, to figure out a solution to this issue. So, if you have been there in my situation, and you can throw some light on it, I’ll appreciate it ![]()
I need to fix/set a group into a specific position on the x and y axis. In other words, no matter what happen outside, it should not move from there. The reason is because I use the groups to establish/simulate the pages sizes for printing, but when the group above (or “previous page”) increase its height, then it push downwards the following page… just messing up everything when printng.
I don’t care if I lose or don’t get to show the whole info contained in the group, I just miserably want the page being printed right. ![]()
Here is a image to illustrate my case, I use the guide color bars for a real page height.
THANKS! ![]()
