A little help with Postmark in backend workflow
Hello! I know I’m doing this wrong, but not sure what else to try. I think my mistakes will be self-explanatory to anyone who knows how to do this, so if you’re a Postmark user or just an API genius, can you please take a look at this screenshot and help me understand what it should look like instead?
Two things, make sure the API call is set to ‘action’ rather than data. Second, the screenshot to the right is the bubble email workflow. After you set the type of your api call to action, it’ll be available as it’s own workflow item. Then you can enter in your details.
Hey there @jay6,
That is because I believe Postmark should be an action itself.
Aha! Thank you, I now have access to it.
Thank you!
