Adjust sizes when collapse floating group
Hey folks,
I build a slide menu bar on the left-hand side of the page and added a button to make the menu bar visible and invisible. (screenshot below).
Menu bar visible
Menu bar not visible
What I want to achieve is to adjust the group elements and hamburger menu in the right-hand side to fit the entire screen when the menu bar is not visible.
Does anyone have an idea if it’s possible to achieve what I want?
Thanks so much for the help.
Bruno
Hi there,
Take a look here. This is my workaround for it.
@FJP - Thanks for sending over the workaround and check it out the screenshots below with your solution
Great work. Glad I could help. Pay attention about the data to show in the reusable elements, that was also mentioned in the topic I referred to. I personally didn’t continue my use case on this due to other priorities. Good luck
Thanks for the hints @FJP. I’ll keep you posted regards this use case :wink:
